Too cold of a plug?
Car: 1985 Trans Am
Engine: Superramed 406
Axle/Gears: 10 bolt 3:73
Too cold of a plug?
I am having a hard time getting my 406 TPI not to run rich. I have Trick Flow 23* heads,24lb Injectors,Timing set at 10* BTC,fuel pressure at 45 and a custom Ed Wright chip.I was wondering if too cold of a plug would cause a rich condition? I have ACFR3LS plugs now because that is what Trick Flow recommend's for a starting point. I get what I think are normanl reading with my AutoXray but This thing runs way to rich
85 TA 406 TPI
Which I will never get to run right
85 TA 406 TPI
Car: 93 S10 blazer
I cant say for sure if that is the problem but on average cooler plugs do run richer.
1990 TA 350 TPI
SPORTSMAN II HEADS
COMP CAMS 224-230@.50
52MM THROTTLE BODY
24LB INJECTORS
1990 TA 350 TPI
SPORTSMAN II HEADS
52MM THROTTLE BODY
24LB INJECTORS
86CamaroDan
Sep 29, 2015 10:08 PM
