*HELP* Installing fuel pressure gauge
Old Aug 6, 2001 | 05:07 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I have all the fittings now, but i can't seem to kill the fuel pump. I have taken out the F/P injector2 fuse (makes it look like it has a wild cam!) and have taken out what i think the the FP relay (the pump doesn't prime) But the car still runs!!! I have let it idle for a few min, but i thought that it died almost instantly. Am i not waiting long enough or do i need to diconnect something else?!
Old Aug 7, 2001 | 12:22 AM
Omar's Avatar
The oil pressure switch is the backup, so that is why it still runs. Unplug the connector above your rear axle, leading into the fuel tank. That will kill your car.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Aug 7, 2001 | 08:28 AM
Omega's Avatar
Engine: LS1 / LS3
Oh yeah! I remember that being said now... well, i got it on anyway. How bad is it to keep the gauge on all the time? If it is bad, are there any quick disconnect fittings i can use?
Old Aug 8, 2001 | 04:13 AM
Omar's Avatar
As long as it doesn't interfere with anything, you can keep the gauge on there all the time if you want.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
MustangBeater20
Oct 29, 2022 09:20 PM
Brcharrelson
Aug 26, 2015 07:47 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
Kaweh
Aug 9, 2015 02:54 PM
