dfi program needed
Old Aug 7, 2001 | 02:40 PM
tples69's Avatar
dfi program needed
I have a 406 with an Accel superram intake that I am trying to get tuned. All the local "experts" are either booked solid 'til 2006 or aren't experts afterall. I was already taken by a shop who was reading the manual and matching my settings to the ones in the calmap booklet. JESSSHHHH!
Anyway, I just received my Calmap and cable today and will start to mess with my fuel maps myself... Is anyone willing to share their DFI configuration with me that has a similar setup?
I have 30 lb injectors, 218/226 @.050 .468/.477 and 112 lsa. Car is an automatic with a 2200-2400 stall, 3.55's. Let me know if anything else is needed.
Thanks in advance.
Elmer
Old Aug 7, 2001 | 11:58 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
I've got a program someone else sent me if you'd like it. I am breaking in my motor first before I hook the DFI up. I'd like to find some other maps to compare this one I have too since it's for 30lb injectors and mine are 24lb. Keep us posted on what you find.
Dan
87 IROC-Z, 6.7 $uperram & cam, Eagle 5.7" rods, Dart 200cc Iron Eagle heads, auto w/ BTE 3000stall lockup, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" headers, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback.
1987 Camaro Z28 - 5.2tpi, auto, 3.73s, ram air, airfoil, ported plenum, !cat, !tbcoolant, !smog, !4th gear - FOR SALE
Old Aug 8, 2001 | 07:04 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I'd send you mine, but it probably won't do you any good. Start with the base map that was supplied and follow the instructions very carefully. There is a good manual at Cruisin peformance. http://www.cruzinperformance.com/accel/
Copy it and learn it. If you have any questions, email me.
Bob '89 Ram Air Formula 350
And until that time when death won't wait, let each man rage against his fate. (O'neill)
My car's homepage
Rider's Ride
Old Aug 8, 2001 | 08:08 AM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
Here is mine;
http://members.aol.com/tunedport350/public/350tpi
Here is what I have;
'86 Camaro SC
'89 350 2 bolt block
Factory crank
TRW forged pistons
'86 Corvette aluminum heads (fully ported)
9.5:1 compression
'86 Corvette TPI Manifold (ported to match runners)
Air Flow Research "Hydra-Rev" kit
1.5 Crane Gold roller rockers
Comp Cams hyd. roller cam
Lift ; .520I/.540E
Duration @ 0.050 ; 236I/242E
L.S.A. ; 110
MSD 6AL ignition
Accel/DFI ecu using White Racing jumper board
Ported plenum (also matched to runners)
24# injectors
52mm throttle body
K&N filters
A.F.P.R. set @ 50psi
SLP Runners
SLP 1 3/4" Headers
SLP 3" exhaust (cat. back)
Random Technologies Cat.
Completely emissions legal
R.O.D. 6 speed trans.
B.W. 3.27 rear
South Side Machine lift bars
Complete '89 Iroc suspension and steering
Old Aug 8, 2001 | 05:00 PM
black bart's Avatar
<font face="Verdana, Arial" size="2">Originally posted by tples69:
Thanks in advance.
Elmer
</font>
I went through the same thing when i got my dfi i called accel and he gave me a list of phone numbers to call i called all of them they all have some excuse for not helping me and after i found out how to program it myself i now know that even the guy at tech support at accel didn't know his *** from a double barrel shot gun.I have a corvette with a supercharged and nitrous oxide injected 406 so my program would not help you but i have a few tips that will help get a good air fuel gauge and someone to ride with you to run the laptop and start tuning but don't do like i did while trying to set fuel on top end i was watching the gauges and blew by a state cop at about 160 boy that cost me. i normally hang out on the corvette forum but just dropped in here to see what you guy's where up to. if you have specific questions you can E Mail me as this post is getting long. IF SPEED KILLS FORD DRIVER WILL LIVE FOREVER
[This message has been edited by black bart (edited August 09, 2001).]
midge54
Dec 27, 2019 04:14 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
