O\E tack, is it accurate?
Just need to know if th O\E tack is accurate?
The other day it looked like it passed the 7,000 RPM mark. It didn't seam like it was at that going that fast.
88 Camaro IROC-Z
350TPI
K&N filter , High flow exgaust (no cat's), automatic tran's shift kit
88 Camaro IROC-Z
350TPI
Car: 89 IrocZ
Engine: L98-ish
Yours doesn't sound accurate, I'd think at 7K the valves would be dancing around a little
Mine seems to be fairly close, maybe within 25rpms of what my scanner reads.
OEM tachs are pretty accurate....at least the ones that I've tested. Problem with them is the update speed. They are so slow to update that under quick acceleration, such as in a racing situation, that they may actually be about 500 RPM behind until a steady RPM is reached. They usually take about 1 second to update where aftermarket racing tachs can update much faster thus making them appear more accurate.
-TA
-TA
Car: Damn
Engine: This
Transmission: New Stuff
Mine is pretty close and upates quickly.
Havn't seen anywhere near 7000 though
'88 RS (originally 2.8)
-350, .040 over, vette alum. L98s, stock tpi.
-305 injectors & chip
-TES headers & edelbrock cat back
-3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
-3.73 gears, 700r4.
on a 2.050 60 ft.
(Damn the 2.8!)
WhteRbt
Sep 21, 2015 09:48 AM
rb85TA
26
Sep 14, 2015 10:29 PM
