Just Noticed This!? MAP?
Old Aug 14, 2001 | 03:59 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I was reading info on my scanner the other day and realized it was reading voltage from what it said was a MAP sensor.
My car is a MAF car and i thought they didn't have MAP sensors? Why was it getting voltage and if it isn't a MAP, what is it? The voltage was slow to change, but did fluctuate. It read like 2.14 and changed a little under throttle.
Help me out. I'm confused.
'88 RS (originally 2.8)
-350, .040 over, vette alum. L98s, stock tpi.
-305 injectors & chip
-TES headers & edelbrock cat back
-3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
Old Aug 14, 2001 | 09:25 PM
breathment's Avatar
well my guess would be the same reason that in the books, the MAF and the MAP sensor are both under the same code. like when the checck engine lights comes on an u decode it, my chiltons manual says that code is either for the MAP or the MAF, whichever u have, im guessing its the same thing with ur scanner. just a thought though.
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
Old Aug 14, 2001 | 10:14 PM
Guest
Guest
Posts: n/a
Good thought, probably true.
Rest assured, your TPI car doesnt have a MAP if it has a MAF. Unless some guy swapped in a turbo buick setup and added 2 injectors and didnt tell anyone...
Old Aug 15, 2001 | 09:16 AM
Car: Damn
Engine: This
I figured it didn't have one but there are separate readings for MAF and the so-called MAP sensor.
The MAF reading is accurate and acts as it should, I'm just trying to figure out where the voltage from this "MAP" sensor is coming from.-it's reading something.
ULTM8Z
Oct 2, 2015 01:25 PM
Giocio
Oct 1, 2015 12:20 PM
ironbmt
Sep 27, 2015 06:00 AM
6998poncho
Sep 25, 2015 02:56 PM
