Idle return spring?
Old Aug 25, 2001 | 05:04 PM
89Irocz23's Avatar
Idle return spring?
ok well when I start it and everything the idle is fine but once I touch the gas it goes to like 1500. I can open the hood and see the throttle is sticking out a little but, but I push it back against the idle stop screw and the idle goes back to normal. I was wondering if I could add another return spring thing or where could I get a new spring or how do I go about doing this. Well thanx
Old Aug 26, 2001 | 03:53 AM
rezinn's Avatar
Clean and lube up your IAC and throttle blades.
Old Aug 27, 2001 | 07:12 AM
89Irocz23's Avatar
come on someone help me is there a way I can add another spring to it..
Old Aug 28, 2001 | 05:17 AM
pontiacpete's Avatar
yes you can buy a carburator return spring hook it onto the bottom of the throttle lever and then onto your alternator bracket
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
mike_c
Aug 27, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
wayshegoes
Aug 17, 2015 12:00 PM
