lots of problems HELPP
Old Apr 6, 2008 | 08:20 PM
stevo the torpe's Avatar
Car: 91 maro
Axle/Gears: 373 locker
okay i have an 89 camaro,i took the 2.8 out and harness had a 88 iroc tpi took harness and motor put into the 89 well it runs in nuetrual but when it gets a load on it it dies and runs like crap and stays like that till i shut it off then it's fine for a lil bit then it does it again.new fuel pump,maf sensor,tps,cts,new 350 motor,trans,fpr.it wont run on the road?it dies stalls,changed distributers did nothing,new coil nothing,some one help this is my daily driver thanks
Old Apr 6, 2008 | 08:43 PM
Car: 91 maro
Re: lots of problems HELPP
no one? nobody has had this prob before?it's an auto.
Old Apr 6, 2008 | 08:48 PM
Car: 91 maro
come on people i aint rich and ive spent over 2500 so far on a car that dont run.iam out of money could it be i didnt change the dash harness?
Old Apr 7, 2008 | 02:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Is the SES light coming on when it is running poorly? (It should come on when the engine dies.)
Old Apr 7, 2008 | 03:36 PM
UR50SLO's Avatar
Car: 86 Turbo Camaro
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
Sounds like a vaccume leak issue. Listen for hissing from somewhere. Those runners are a PITA to install and seal up. I dispize working on them
Have you taken a look at the IAC (idle air controll valve) that's what really makes it Idle correctly.
Make sure there is NO leaks in the ducting between the MAF and the throttle body.
PCV all hooked up correctly?
EGR Stuck open or vaccume hooked to it wrong causing it to open?
Sounds like somthing simple...
~Scott
Old Apr 7, 2008 | 06:23 PM
Car: 91 maro
yea the ses is on.when running poorly i gives me a code of an ignition problem.yes i clean the iac.the maf,fuel pump,cts,imts,tps.it runs good cold til warmed up and then it wont go down the road like she's starving for gas o and i have a new fpr.or loosing fire,thanks for replying
thanks tell me if u can think of something else.
Last edited by stevo the torpe; Apr 7, 2008 at 06:25 PM. Reason: Automerged Doublepost
Old Apr 7, 2008 | 07:10 PM
five7kid's Avatar
What ignition code is that?
Old Apr 7, 2008 | 07:35 PM
UR50SLO's Avatar
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
Yea... what ignition code????? 43? other?
If it's good when cold it's somthing when it go's into "closed" Loop.
O2 hooked up? Need to look at the perameters that the computer rely's on when in closed loop then.
~Scott
Old Apr 7, 2008 | 07:46 PM
Car: 91 maro
code 36,distributer blah blah but i got code 36.also the new fuel pump sounds horrible like louder than old one?bad pump?doa
whats code 43?
Last edited by stevo the torpe; Apr 7, 2008 at 07:47 PM. Reason: Automerged Doublepost
Old Apr 8, 2008 | 12:00 AM
five7kid's Avatar
Code 36 is MAF burn-off circuit, not ignition.
Have you put a fuel pressure gage on it?
Old Apr 8, 2008 | 04:31 PM
Car: 91 maro
no fuel pressure gauge dont have one.but the maf is new.
Old Apr 8, 2008 | 05:04 PM
five7kid's Avatar
A new MAF won't affect the burn off circuit.
A fuel pressure gage is a good investment.
Old Apr 8, 2008 | 08:33 PM
Car: 91 maro
i didnt no the 88 had a burnoff where is it?
Old Apr 12, 2008 | 09:31 PM
Car: 91 maro
where is the burnoff?
Old Apr 20, 2008 | 04:37 PM
Car: 91 maro
okay i got it running good but now it has a miss/upper rpm
jhawkeye
May 25, 2022 06:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
Infested
May 22, 2018 11:56 PM
g.l.mos
Aug 22, 2015 12:02 AM
Fronzizzle
Aug 17, 2015 02:52 PM
