TPI differences, 86 and 89..
Old Apr 20, 2008 | 02:35 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I have a spare TPI setup laying around from my 86 vette that I've spent a lot of time porting and I'm going to polish it up, my question is can I use it on my 89? I know the differences with the cold start injector but as far as I can tell the difference is only in the runners and the fuel rail, am I correct in that? Basically I'd like to know if the base and the plenium's are the same.. thanks!
Old Apr 21, 2008 | 03:04 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: TPI differences, 86 and 89..
The base is different, it has the old style bolt pattern. On 87+, the 4 middle intake bolts go into the heads at a different angle.
Old Apr 21, 2008 | 12:41 PM
89RsPower!'s Avatar
good call, completely over looked that one that should have been obvious.. is that it? That's pretty easy to fix..
Wade787b
Sep 29, 2015 01:15 PM
masonta
Aug 31, 2015 10:14 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Jlanz55
Aug 17, 2015 07:15 AM
Sanjay
Aug 12, 2015 03:41 PM
