will this be enough????
Old Nov 27, 2001 | 09:27 PM
Stang Eater's Avatar
i am currently builg a 355, keith black flat tops, dart S/R torquer heads and i am not completely decided on a cam yet, but will be hyd. roller, somewhere along the lines of the HOT CAM but more effective down low. My question is, if i port and polish all of my intake(91 SD tpi)buy a 52mm TB and find some #24 lb/hr injectors, will that feed it enough if i have a chip burned???????
Old Nov 27, 2001 | 09:53 PM
airdeano's Avatar
stang eater,
depending on what your demands are is the factor
on the cam. a generous port match and blend
is fine. depending on the amount of control
you want, the LPE 211/219 in a fine choice.
also, the 219/219 is good, but a larger tube runner
is desirable. to hot cam compression is best
at 10-10.5:1, and if your vehicle is 3400# or
heavier.. look for a lil gear help. this is
more upper like the 219/219.
24# injectors will be plenty. and after your done
changing yes a prom would be necessary
airdeano
