will 86 maf work on 87 TPI????
Old Dec 13, 2001 | 04:13 PM
CloudZStrife's Avatar
I'm looking at an MAF sensor from some guys car but will an 86 Sensor work on an 87 TPI Iroc??? I have numbers if you guys need.
87 IROC-Z, 3.23 posi, new 305 TPI, and soon to get new trans and world torquer 305 heads
Old Dec 13, 2001 | 04:53 PM
jmr85TA's Avatar
Yes it will work. The onl year that is different is 85.
jmr85TA's Avatar
Yes it will work. The only year that is different is 85.
Old Dec 13, 2001 | 07:37 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
Actually, the 85 will work also, I used the same one I've had after I upgraded to the "165" ECM...
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
http://www.geocities.com/transam85tpi/
Old Dec 13, 2001 | 10:54 PM
Vader's Avatar
Cloud,
The V-8 MAFs from '86-'90 are all Bosch analog units, and should be compatible. As long as the replacement has a five-wire connector that matches the wiring harness, you should be safe. The Bosch P/N is G28D 213 D04, and the GM P/N is 14094712.
Kevin WOULD have to bring up the "conversion" factor, just to confuse things.
If it doesn't work out for you because the MAF is not functional, check into a Wells MAF as a replacement.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Dec 14, 2001 | 12:32 PM
cool I'm lookin at one on ebay and it is functional if Not I'm gonna be real pissed...lol
Old Dec 19, 2001 | 04:46 PM
Car: 1985 Trans Am
Only here to help..... albeit from a LONG WAY AWAY.... LOL
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
