problem racing injectors
Old Jul 2, 2008 | 07:14 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
ok this makes no sense. how can we just pull the injectors out if they are down inside the hole. the clips will rotate but WILL NOT come out. how are we supposed to do this without removing the plenum/fuel rails.
[IMG]file:///C:/DOCUME%7E1/User/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
Old Jul 2, 2008 | 07:57 PM
jcp74's Avatar
Re: problem racing injectors
There are 4 bolts that hold the fuel rail to the intake manifold and keep the injectors and fuel rail in place.I just got my new injectors today! I have my whole intake off including my manifold. I think you must take the plenum and runners off.
Old Jul 2, 2008 | 08:01 PM
Car: 1986 IROC-Z28
ok its just people on iroczone are saying u dont have to remove the fuel rails
Old Jul 2, 2008 | 08:19 PM
jcp74's Avatar
Yeah, I saw an article similar to it, I had a bad intake manifold gasket, so I ripped the whole thing apart, But I do know there are 4 bolts holding the fuel rail and injectors down. An I'm looking at my haynes book, it looks like the injectors stick into the fuel rail about a 1/4 inch.
Old Jul 3, 2008 | 06:38 PM
Car: 1986 IROC-Z28
here is slideshow of progress so far
http://good-times.webshots.com/slide...63990707IMuOlm
autozone was supposed to have my gaskets today but they dont. its supposed to thunderstorm tonight so no more work until tomorrow. taped up all intake holes and put the car cover on.
Old Jul 4, 2008 | 12:32 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You have to remove the 4 bolts that hold down the fuel rails. 1st, disconnect the fuel lines at the front of the fuel rail. 2nd, remove the fuel injector connectors. 3rd, remove the 4 bolts (its probably a 10mm wrench). You could apply a little bit of WD40 on the bottom injector orings. 4th, pull up on the fuel rails, all 8 injectors will pop out the the bores in the intake manifold. Once the fuel rail is free, to remove the injectors from the fuel rails, carefully remove the clips that you show in the pic above. I think that they rotate around to a certain position, then can be removed.
Street Lethal
Apr 30, 2019 12:14 PM
italiano67
Dec 11, 2016 09:21 AM
theurge
Aug 21, 2015 12:46 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
