Automatic to 5 spd With TPI
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Axle/Gears: Uh, Haven't investigated this yet
I'm actually swaping a TPI setup into my 5 spd Carb car. The TPI, ECU and harness came out of a Automatic car. I know I'll have to modifiy the harness for reverse lights and such, I'm just wondering if the ECU needs anything to run correctly on a 5 spd rather than an Automatic.
Will there be any running issues with the engine since it will be a stick?
I tried searching and didn't come up with anything.
Car: 85 335IROC Camaro
Engine: 335 tune port
Transmission: 700r4 Stage 2
Axle/Gears: 3:73
Re: Automatic to 5 spd With TPI
you'll just need the tranny the five speed setup clutch pedals harness and computer froma 5 spd car and it'll be plug n play.
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
My car was orginally a 5 spd car. I wish I could change the title to this thread.
I guess I want to know what will happen If I use a Auto TPI ECU with a 5 spd trans. Will it run right?
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Like Aaron said you can use the ecm. You will need to get a chip made for the 5spd and get a vss signal from the tranny.Any tranny shop should be able to get you the proper parts to do that depending on what tranny you have whether its a cable driven speedo or not.From my experience you can essentially start the car and drive it without having vss signal....but i dont recommend it for a long period of time because the ecm does rely on vss for proper management due to engine speed once it knows your in gear.Right now my tranny took a dump on me and i dont have vss at all.My car drives but i dont have second gear...mind you the ecm knows im not in park or neutral but doesnt know to advance timing etc when i start getting up in revs so it drives like a bag but it made it to my shop.
Axle/Gears: 3:73
yeah they hit the nail on the head dude the process is easy, and in most cases you find your ecu for the 5 spd from the donor car you got the 5 spd from. unless your buying it new from GM and in that case i would assume it would come with one as well.
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
