How should I start my IROC up after two years?
Old Jan 8, 2009 | 06:33 PM
GM Man's Avatar
Car: 1986 2.8 Camaro
Engine: TPI 350
Transmission: Tremec TKO
So two years ago I stored my IROC in the garage, filled the tank all the way up and put Sta-Bil in it when I stored it. Now my question is should I use this gas with a new fuel filter or should I try to siphon it out and put in fresh gas?
Thanks..
Old Jan 8, 2009 | 06:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How should I start my IROC up after two years?
If it's only been two years and you stabilized the gas, just put the key in and turn it.
Old Jan 8, 2009 | 06:52 PM
TransAM Joe's Avatar
How long will STA-BIL Fuel Stabilizer keep fuel fresh? For 12 months when mixed into fresh gasoline. Doubling the dosage will keep fuel fresh for up to 2 years.
Old Jan 8, 2009 | 07:05 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Just start it up. It may run rough for a bit, but it'll eventually smooth out.
I had a tankful of Sta-Bil treated fuel in my motorcycle for over two years. The machine started and ran fine, but I only got 85 miles out of those 4.5 gallons of fuel.
Oh yeah, you'll need to charge the battery before you "just start it up".
Next time, hook up your battery to a maintainer. I highly recommend one of these:
http://www.batterymart.com/p-battery...y-charger.html
Old Jan 8, 2009 | 07:08 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I've regularly started vehicles up with unstabilized fuel that's been sitting for longer than that with no problems.
Old Jan 8, 2009 | 07:50 PM
Russ-So Cal's Avatar
The fuel is probably ok, but I would either pull the diostributor and spin up the oil pump to get oil pressure up like you would a fresh rebuild before starting, or I would at least get the battery up really good and pull the coil wire and spin it over on the starter until you have good oil pressure. After you get oil pressure spin it for another 10 seconds or so to lube everything good before re-installing the coil wire for a start up. Once it starts let it idle for a while to circulate the oil really well before you rev it. The cylinder walls may be dry as well as bearings after sitting that long.
Old Jan 8, 2009 | 08:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not likely, the oil film lasts a looong time.
Old Jan 8, 2009 | 08:24 PM
I wouldn't gamble on it. It is a lot easier to presurize the oil system first than it is to rebuild the engine because I thought the oil film was still there.
Old Jan 8, 2009 | 08:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's nothing you can do before start up that will fix improper storage. If there was no oil film, you'd have condensation and corrosion, and nothing you did could help that. Only two years isn't going to be a problem, though.
Old Jan 8, 2009 | 08:54 PM
Alex IROC Z-28's Avatar
Car: Camaro IROC Z-28 1987
Transmission: Automatic
Talking about storage, I do not do anything special on my car in the winter, but I turn on the car every 3 weeks ....leave on iddle, and rev a bit for 1/2 hour.....
How do you guys storage the cars?
Old Jan 8, 2009 | 09:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I park them and leave them. Start them up every month or two and run them up to full operating temperature. Sometimes if I know I'll be leaving it a while I'll put fuel stabilizer in, but usually not.
Old Jan 9, 2009 | 09:14 PM
GM Man's Avatar
Engine: TPI 350
Thanks for everyone's opinions, once I get it fired I'll find out how it runs!!!
Old Jan 9, 2009 | 09:36 PM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
charge the battery get in start it up
let it idle for few min then drive it
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
