350 vortec engine build
Old Feb 19, 2009 | 07:55 PM
watman02's Avatar
Car: 91 Z28
Engine: LB9
Transmission: 5 speed
Axle/Gears: 3.73 limited slip stock
Hey guys hears my goal first to run in the 12's with no power adders and do it all day long
I have 350 vortec headed engine at a shop right now and what i got so far is a TIPs 52mm tb TIPs large tube runners and was gona buy a Edelbrock vortec base until i was reading some other posts (mainly the "quest for better flowing tpi") and heard about FIRST injections vortec base does anbody know what it flows??
My engine shop stated he was going to zero deck the block and put in flat top pistons to hopfully get mid 10-1 compression out of it perfrom a 3ange valve job on the intake 5 angle on the ex side and polish and remove some casting ridges in the intake he stated he didnt think i need to get bigger valves??? and stated that roller rokers were not nessasary and wouldnt recommedn spending the money
my cam choices are the TIPs the ZZ9 or ZZ409 cams or compcams xr276hr or the 268xfi hr13 or any othes you guys recommend that might work better.
I will also be getting a chip made or learn to do it my self have decided witch yet. but i have picked up quit abit from reading LOTS of past and present posts and I thought id just ask you guys
Old Feb 19, 2009 | 11:36 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 350 vortec engine build
Stroke it - build a 383. Forget the 350. Heres what I'd build:
- 5.7 Roller block, bored .030, 0-decked
- Vortec heads, freshened, ported at least on exhaust side, machined for extra lift, big OD springs, screw-in studs and guideplates
- 3.75" steel stroker crank (383ci)
- Pistons to make 10.25 or so CR with 64cc heads
- Thin head gasket (steel shim is ideal) to keep quench tight
- xr276hr camshaft (I think thats the roller version of XE274 right?)
- Comp ProMagnum rockers
- Hooker 2055 or the full length 1.75" Hookers
- 3" catback of your choice, 3" cutout after Y-pipe if using shorties
- Holley Stealth Ram manifold to replace TPI (manifold and fuel rail set is probably under $500)
Then add a 3.42 or 3.73 gear, and a matching converter if using an automatic... maybe a 2500 stall.
Old Feb 20, 2009 | 08:18 PM
watman02's Avatar
Car: 91 Z28
Engine: LB9
I dont really want to build a 383 at this time as i think it will outflow the tpi witch i would also like to keep at this time since ive allready spent the money on the stuff. BTW where do i find a SR for less than 500$???
I think ill need at least 315-330 rwhp to make it into the 12's do you guys think it can be done??
Old Feb 21, 2009 | 08:03 AM
skinny z's Avatar
I run 12's with a carbed xr276hr Vortec 350.
3650 lbs race weight.
That works out to about 330 rwhp depending on whose hp calculator you use. I will say it's all in the first 60' though. I'm absolutely sure that if I could get my 60' times quicker than 1.9x's (best of 1.78) the car would be mid 12's.
Like you mentioned, 20+ mpg driving home from the track.
Old Feb 21, 2009 | 09:14 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
stealth ram is over 800(can) with rails, not that cheap anymore, just sold one at work yesterday, also, considering most steel shim heads gaskets are .015" to 0.020", you wouldn't want a zero decked engine. Ideal quench is between 0.040" and 0.065", if it was zero decked, and you ran that thin of a head gasket, your quench would only be 15-20 thousands of an inch.
Old Feb 22, 2009 | 03:01 PM
Air_Adam's Avatar
A 0-deck is usually not actually a 0-deck... its really more like .005" clearance. Ideal quench space is around .030-50, .050 being on the looser end.
Old Feb 25, 2009 | 06:10 PM
watman02's Avatar
Car: 91 Z28
Engine: LB9
so you guys dont think a zero decked block is a good idea??
I also have found that summit sells hsr for 360$ with out fuel rails so im going with that. anybody used a hsr and what else do i need to know about swapping to this setup any tip/tricks???
xflgkingpin: link to vortec heads???/ there was no link???
Old Feb 25, 2009 | 06:21 PM
Car: 1979 Malibu
Engine: Blown LSx
you need the fuel rail kit, PN 534-186, mr gasket water neck 2661, some form of aftermarket throttle body
Terrell351
Jun 13, 2021 01:13 PM
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
sreZ28
Aug 14, 2015 07:48 PM
Jake_92RS
Aug 11, 2015 10:39 AM
