Will this combo work?
Old Apr 8, 2009 | 09:21 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Here are the parts I want to get to beef up my TPI system:
- Edelbrock high flow base
- BBK AFPR
- SLP Runners
- Fully ported plenum
- 52mm holley TB
- Haven't decided injectors yet. Will research that when I finally get the 305 "built".
I already have the SLP runners and the fully ported plenum installed. My question, is that I have read in several places that the SLP runners and edelbrock base WILL NOT work together because of clearance issues, but I have seen a couple people who use this combo. Can anyone shed some light on this?
Thanks.
Old Apr 12, 2009 | 08:52 PM
fastsspr's Avatar
Car: 1985 Yellow Iroc Z w/LS interiors
Engine: 305ci 5.0L
Re: Will this combo work?
why spend in edelbrok base when you can port you factory one with excellent results? i ran 12s with factory ported base.
Old Apr 14, 2009 | 11:06 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
It will work. I havent heard of any problems but if need be you can probebly grind a little away.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
