Replacing The CTS
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Replacing The CTS
When replacing the CTS, how much coolant should be drained from the radiator to avoid spillage when removing it from the intake manifold. Also, if no coolant is drained beforehand how much will spill out? Are we talking someone opened up a faucet or a small trickle?
The reason I ask is because I live in a neighborhood with a stupid HOA who have strokes over spilled milk.
Car: 1989 Camaro IROC-Z28
Engine: Rebuilt 350TPI (see sig)
Transmission: is being replaced...
Axle/Gears: 20 year old G92 Borg-Warner 3.45
Re: Replacing The CTS
When I replaced mine only a little bit dripped out maybe 2 measuring cups worth but this could also vary for you but if you dont want to drain the whole thing I would just place a typical oil drain pan under the front of your motor and take the sensor out you should be fine
