87 305 tpi problems
Old Apr 25, 2010 | 12:03 AM
87irocz2887's Avatar
87 305 tpi problems
my 87 iroc 305 tpi misses and blows black smoke out the exhaust pipes. I have to pump the throttle to get it started. It ran good for a while then it started acting up. I've had the battery out a couple times. I'm not sure where to start. Any suggestions?
Old Apr 25, 2010 | 12:06 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: 87 305 tbi problems
it could be missing because of over fueling or it could be ignition causing the misfire. i would look at the ignition system, make sure everything is in good condition. check codes. then look into the fuel system. injectors go bad over time.
Old Apr 25, 2010 | 12:55 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
I would do a tune up, run some injector cleaner through the system, and check the timing. I have mine set at 6 degrees, and I have no problems.
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
