hard start, rough idle.
Old Sep 29, 2010 | 06:06 PM
randyz91's Avatar
Car: 1991 z28
Engine: 5.7 tpi
Transmission: th700r4
Today I got in my car, It started fine, idled great, drove it 10 miles, shut it down for 20 minutes. Got back in and fired it up. Started hard! Cranked it over and it would only run, or start with the the pedal down. I kept it running and drove it back the 10 miles, it ran great all the way back and idled and restarted just fine on arrival. Is it the I.A.C? I was nervous when it happened. Thanks for your input. Randy
Old Sep 29, 2010 | 06:16 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: hard start, rough idle.
Did the SES light come on? Any codes?
Old Sep 30, 2010 | 05:57 PM
randyz91's Avatar
Car: 1991 z28
Engine: 5.7 tpi
thanks for replying! no ses or anything else. after I got on the road, up to speed I had no problems. I have not driven it since so I don't know if it went away, but I like to just jump in and take off occasionally and this makes me nervous. I will drive it to work tomorrow and see what happens. I was just wondering if this happened to anyone else. Once again, thanks! I'll keep you posted. Randy
Old Sep 30, 2010 | 08:51 PM
red rock's Avatar
Car: 1987 iroc
I hope for you it works O-K, because with a problem that comes and goes with no codes is going to be a bear to figure out. Could be IAC, but there again it should have thrown a code. Good luck.
Old Oct 1, 2010 | 04:57 PM
randyz91's Avatar
Car: 1991 z28
Engine: 5.7 tpi
Thank's for the reply! I drove the car today, no problems. But, I guess that I've learned that these intermitent problems do not just go away. I guess I'll keep on driving it until it happens again. If it a'int broke, you can't fix it. Randy
Orr89RocZ
Apr 25, 2016 08:28 AM
db057
Aug 22, 2015 08:17 PM
cstrobel65
Aug 15, 2015 10:19 AM
