Will getting computer end my woes?
Old Oct 16, 2012 | 01:22 AM
CombustoBird89's Avatar
Car: 1989-TPI-GTA
Engine: 5.7
Axle/Gears: Limited Slip/Stock Gears
Have checked everything i can think of, yet engine won't come to life. If you tickle purple wire from distributor and hear injectors clicking, does that mean drivers in computer are good, or does that just bypass computer?
Old Oct 16, 2012 | 06:26 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Will getting computer end my woes?
You have bad wiring ,
only the computer makes the injectors work after it gets the reference signal from the dist that the engine is turning over
TPI Corvette shown but F-Body wiring from dist to computer the same
Old Oct 16, 2012 | 08:38 PM
Car: 1989-TPI-GTA
Engine: 5.7
Ran through connections, and voltages again at 2 connectors at ecm and distrbutor. Everything seems fine except for the grounds...when ohming grounds at ecm connectors to various ground points in engine bay, i get 4.5 ohms at various chassis ground bolts...2.0 ohms going directly to battery ground...yet i get a low ohm reading when touching engine itself (0.5 ohms) So..should i bypass and give computer lower ohm ground (0.5 ohm) and see if this cures nostart (before actually replacing wires of course) Not knowledgeable in eletronics enough to know if these differances in ohms means anything, so any help is appreciated alot!
Old Oct 18, 2012 | 09:26 PM
Car: 1989-TPI-GTA
Engine: 5.7
Seem to have all parts working...i now have spark and injectors pulse....i am getting about 10 volts while cranking as i'm backprobing computer connection. Does this sound like enough for it to work correctly? I do remember reading that it gets glitchy at 8 volts. Could it be there is bad fuel trapped in crankcase and cylinders from leaking injectors b4 replacing? Thanks again for any suggestions on where to look next.
Old Oct 20, 2012 | 07:16 PM
Car: 1989-TPI-GTA
Engine: 5.7
Just want to follow for others future searches: "My birds alive!" Hehehe...Started as starting fuid only starts...replaced injectors..pickup coil and used a old GM icm to replace a very used one. Purple wire on dist. made pulses, but not while cranking...there was alot of corrosion on old icm..cleaned it, and shes alive again.
Of course this sounds fast, but many, many other tests were performed on wiring and components too. Good Luck
sweet_87_iroc
Sep 25, 2015 10:01 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
zayne0
Aug 24, 2015 07:22 PM
86IROC112
Aug 21, 2015 07:20 PM
jharrison5
Aug 19, 2015 05:53 PM
