tpi differences?
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
tpi differences?
So i was looking in to swaping my car from carb to tpi and found a tpi set up from a 85 vet. I did some searching and read that the 85 tpi is different from the rest and that the 86 to like 89 had 9 injectors one for cold starts i guess. I was just wondering what year ones i should be looking for and what would be a good tuning system for it. Should i look into one of the holley ecm's or would somthing like that even work?
thank you Jesse
thank you Jesse
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: tpi differences?
You can play mix and match with them if you know what you are doing
You buy whatever year TPI intake you can get your hands on at a good price
For a computer (ECM ) 86 - 89 is preferred , faster , cheaper and more around .You need a ECM and matching wiring harness for your car
Not that it makes much difference to operation but 86 -88 had a cold start injector , 89 had the cold start built into the programming.
Engine: 355ci
Ok so from reading the link and from what vetteoz said my understanding is that all I need to do is get any tpi intake and depending on the year might have to machine the center holes of the intake but other then that I just need to pick up an ecm and harness? So now I guess my question would be what style should I be looking for the mass or speed density? My engine is beefed up I guess you could say 11:1 compression comp cam 08-503-8 cam promaxx 2121 heads.
Thanks for all the help, Jesse
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/engi...-manifold.html
It comes with the 90-92 sd plenum not a bad deal.
Sanjay
Aug 12, 2015 03:41 PM
