Go Back  Third Generation F-Body Message Boards > Tech Boards > TPI
Reload this Page >
Vapor canister purge solenoid for 92' 5.0 TPI
Old 01-06-2014, 03:27 PM
MeenZ28's Avatar
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
Where can you buy a replacement? I've looked everywhere and can only seem to find the entire canister. The one Rockauto shows is wrong. Can you just buy the solenoid or am I stuck buying the whole canister with it?
Should look like this ----
MeenZ28 is offline
Old 01-06-2014, 03:59 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Vapor canister purge solenoid for 92' 5.0 TPI
its built into the canister !
Tuned Performance is offline
Old 01-06-2014, 04:51 PM
MeenZ28's Avatar
Transmission: A4
No it's not. I took mine out....
MeenZ28 is offline
Old 01-06-2014, 05:07 PM
Engine: Lb9
Transmission: M20
Have you contacted your local gm dealer to see if its sold separately from the gm 17092109 acdelco 215-163 ?
You may compare a acdelco 214-619 and see if that matches.
Old 09-14-2018, 07:50 AM
1991vortech335's Avatar
Car: 1991 Convertible Z/28
Engine: Vortech 335 TPI
Transmission: Trans-Go 700-R4
I know this this is an older thread but you can find the purge valve still available at Summit. Iím desperately searching for the whole canister and cannot find one anywhere. If you might know of a spot to order from I would be very grateful!
[IMG]http://i.ebayimg.com/t/82-92-Camaro-Charcoal-Vapor-Smog-Emissions-Canister-17088067LF-350-TPI-GM-SBC-/00/s/OTYwWDEyODA=/z/L6sAAOxyVaBSwyIo/$_57.JPG
1991vortech335 is offline
Old 09-14-2018, 10:10 AM
if you can't find the exact part and aren't overly concerned with originality, you can always get a generic and make it work. the solenoid itself is nothing special... just need to open and close with a 12v signal. something like this can be mounted somewhere off the canister and then plumbed and wired in.
https://www.ebay.com/p/A-c-2-Port-Vacuum-12-Volt-Solenoid-Shut-off-Valve-959001-Normally-Closed/1658786138?iid=401283832888
ULTM8Z is offline
Old 09-14-2018, 05:46 PM
Pro
Car: 1992 Z28 and 1995 Silverado
Engine: 5.7 TPI and 5.7 TBI to TPI convert
Transmission: 700R4 and 4l60E
Axle/Gears: G80 3.23 and open 3.42
No need for that. The truck ones plug right in
https://www.autozone.com/engine-mana.../45380_0_12209
Pro is offline
1992 Trans Am
02-03-2019 04:10 AM
ron reece
Southern California Area
10-07-2015 01:11 PM
Ghettobird52
09-03-2015 05:18 AM
Sanjay
08-12-2015 03:41 PM
Quick Reply: Vapor canister purge solenoid for 92' 5.0 TPI
Advertising
Featured Sponsors
Vendor Directory
Contact Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
