Code 42!
Car: 1992 camaro rs
Engine: 92 350ci carbed
Transmission: 700r
Axle/Gears: Stock 10 bolt 2:73 gears 😭
Code 42!
89iroc is throwing a code 42. It runs smooth idles smooth, but has a big exhaust leak on the passenger side manifold and just feels like a dud. No torque
Car: 87 IROC Z
Engine: 5.7
Re: Code 42!
Well, since you can do a google search for the code, replace the manifold gasket for the exhaust problem, did you have a question for the board or just letting us know how your cars feeling?
Car: 1992 camaro rs
Transmission: 700r
Re: Code 42!
Letting you know how it's feeling because people obviously never post things on this site if they need help. Nice to have another sarcastic ***** to add to the list of things that don't help
Car: 1992 camaro rs
Transmission: 700r
Re: Code 42!
Just wanting to know if the exhaust leak can cause the code 42, and the knock sensor or whatever sensor to go off and cause loss of power, as I stated before. Thanks
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Code 42!
exhaust leaks on the motor WILL play hell with TPI .fix that first.code 42 has to do with the ign. specifically the module behind the relays on the right side near the brake booster.or it could be that the brown wire with a black stripe (EST bypass) is un plugged .good luck and let us know how it turned out
Car: 1992 camaro rs
Transmission: 700r
Thanks! My bypass is plugged in il have to check out that box
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1992 camaro rs
Transmission: 700r
Now I have a new icm(old one tested bad) and the wiring is all good but it still throws code 42. Still feels like a v6 too lol
Car: 1989 pontiac firebird formula
Engine: 5.7 350 tpi
Transmission: 700r4 i think
Re: Code 42!
I spent a lot of time dealing with an issue like this but I didn't get a code 42, have you checked the grounds and the wires off of the ecm and your timing? also check the module on the distributor and coil. if its the electronic spark timing it could be anything from that circuit sorry I cant be more help.
Car: 1992 camaro rs
Transmission: 700r
Car: 1992 camaro rs
Transmission: 700r
The code came back on after a few times running the car so I replaced the ECM and it hasn't shown up since, it ended up being the ECM and a bad icm.
