Code 44
Old Jul 2, 2014 | 07:42 AM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
Code 44
I have finally got a code to appear on the ses light. the car is a 91 that was converted from tbi to a 92 tpi a few years ago. recently I have been having running issues. it starts and idles fine, when you get it in the 2k-2500 rpm range it sputters and pops in the plenum. it feels like its losing power when driving.
fuel pressure is at about 40 with new injectors, fuel filter and afpr opened all the way. ive switched out everything and tested the tps and iac.
i had been driving the car a lot over the last few weeks and finally got a code 44.
lean o2. the wire looks good so any ideas?
Old Jul 2, 2014 | 01:53 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: Code 44
As a matter of course, the O2 sensor should be changed around every 30K (IIRC).
Might want to pull a few plugs and see what they look like...if sooty, then definitely O2 sensor.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
