Persistent stalling problem
Old Jul 3, 2014 | 03:00 AM
profiveo's Avatar
Car: 1992 Camaro Z28
Engine: 350 L98
Car is a 92 Z w/L98 700r4. The car seems to have a stalling problem that just wont go away. The car stalls whenever you put it in gear to reverse or sometimes when stopped at a light. New parts that have been replaced in hopes of fixing it include; injectors, fuel pump, fuel filter, iac, tps, torque converter, along with various tune ups. Been thinking it could be a vacuum leak, but been replacing/inspecting lines with no change.
Could an excess amount of fuel tank pressure have anything to do with it? When removing the gas cap there seems to be allot of pressure built up in the tank.
Any other ideas of input?
Old Jul 4, 2014 | 02:36 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Persistent stalling problem
Haven't done anything with the IAC? (you know, that part that actually controls idle?) Sounds like it isn't reacting as fast as it should. You can try pulling it out, and cleaning the snot out of it.... if that doesn't help, next step would be to replace it.
Some pressure in the gas tank is normal. Considering the TPI system operates at 43 PSI, pressure in the tank isn't even a consideration.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
