Distributor question
Hi guys,
when removing my distributor cap on my 86 5.0 TPI , I noticed that there were two plugs on the cap but also a small plastic covered "earth Connector"
does anyone know where this should go ?
Many Thanks
Many Thanks
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Distributor question
I think somebody cut the crap out of your wiring,everything is a plug and play on the distributor.
thanks for the pics , the distributor on mine has the two connectors which are perfect however this small single "brown connector" comes out of the same loom as the other two connectors, it may meant to be unplugged but I would rather check
mine is the dizzy with the coil pack on the top, its an 85 model
you can see the brown connector in the pic
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
That connector does plug into the distributor. That is the tachometer signal wire.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
In your photo, do you see where the dirty red wire plugs into the cap?
Notice where it plugs in, there's the words "BAT" molded into the cap? Right next to where it reads "BAT", it reads "TACH".
Engine: 5.0 EFI
Does any of your gauges work??particularly the oil and the tack??
