Another cam selection
Car: 6.2L pontiac firebird
Engine: 383 stroker
Axle/Gears: 373
I've been trying to figure out what can would be best suited for my build. I have a 91 firebird 5.7l board 30 over. It has trick flow heads 175 cc and 56 chamber. I know there small heads but they were really cheap and they flow better then stock. I have the edelbrock base and runners ported. 52 mm bbk throttle body shorty headers 24 lb injectors, 1.6 roller rockers. Compression is 10.5:1 and its hooked up to a 700r4 beefed up with a stage 2 shift and a 2600 stall. The car is mostly going to be used for weekend driving with the occasional trip to the track. Looking for 2000-5000 or more rpm range . Any help with a cam choice would be appreciated.
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Another cam selection
here is a little secret that I have been keeping
I bought the lt4 hotcam from them and they already advance it 3 degrees so you can run the cam straight up and get more power out of it. I think it was close to half price from buying it at a retailer
http://willhoitescams.tripod.com/
Engine: 383 stroker
Axle/Gears: 373
So with the lt4 with a 3 degree advance built into it should give me a bit more top end? What are you running for your engine combo?
Engine: 350 tpi
I have a 350 with 305 heads 1.94 valves and a lot of porting. my runners are slp
Car: 88GTA
Engine: 5.7TPI
ported out tpi open headers lt4 hotcam - YouTube
Engine: 383 stroker
Axle/Gears: 373
That sounds pretty dam good what kind of hp/tq numbers? And rpm range? I have megna flow cat back with a 3" cut out I'm wanting to get this car going it's been 5 years since I last drove it
Car: 1983 G20 Chevy
Transmission: 4L60
Engine: 350 tpi
I talked to Willhotes and asked him if the cam would make more power if I degreed it and he told me to run it straight up because they had already advanced the cam. call him and ask about it
Engine: 350 tpi
it makes power all the way to about 5600 rpms. my runners are ported a little past the half way mark. I could not tell you how much hp and tq its making but it pulls pretty hard.
Engine: 350 tpi
I just called them and they said the cam is 130 dollars plus 15-20 shipping. they make all kinds of cams. and the advance on the cam is 1-2 degrees I was wrong
But 130 for a roller cam that is made from the same cores as everyone else uses is an incredible deal
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Hotcam can work but may be alittle more than what you want in that combo.
Something alittle smaller advertised would be alittle tamer at idle.
5000 rpm powerband is more like an comp xe 212/218 deal. Hot cam equivalent 218/224 could work well and has less advertised duration so alittle better idle manners
