1987 Iroc 5.7
Re: 1987 Iroc 5.7
If your fighting a code 36 you might have the wrong relays installed.
https://www.thirdgen.org/forums/tpi/...6-44-86-a.html
Re: 1987 Iroc 5.7
replaced burn off, maf, maf relay with GM. My problem is when cold it starts fine but idles poorly, sputters, pops and a bang noise if I rev it up and sounds like it is sucking air at the MAF. Once it warms up it idles good and the sucking air sound goes away. I have no check engine light on, checked for vac leaks, all tuned.I just keep replacing parts with no success.
I'mAllIn
08-26-2020 04:26 PM
