cold start only with gas pedal floored
Old May 18, 2024 | 08:26 PM
c-137's Avatar
Car: 85 t/a
Engine: 5.0 tpi
my car (85 T/A 305 TPI) used to start up fine when cold, it would fire instantly. recently when starting cold in the morning (it's May so not that cold, maybe in the 50s F) it will just crank but not fire. But if I push the gas pedal to the floor (letting in a lot more air), it'll start up. Once it's warm I have no problem starting, and it runs great. So I'm hoping I can access the collective knowledge of this forum to help me figure this out. I won't list it all, but I have gone through the engine and most things are good and/or new... spark plugs, cap/rotor, sensors, etc. I'm thinking maybe something with the IAC, it's new but I have the old one, might try reinstalling the old one to see if it helps. The car runs good and pulls nice and hard up through the rpm so I'm pretty sure it's not an ignition timing issue, but I'll check the timing when I get a chance. Has anyone had this problem before?
Old May 19, 2024 | 07:24 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: cold start only with gas pedal floored
Is fuel pressure dropping fast after prime when warm?
sounds like a leaking injector or csi.
Old May 19, 2024 | 08:35 AM
c-137's Avatar
Car: 85 t/a
Engine: 5.0 tpi
idk.. good idea. I'll check the fuel pressure when I get a chance.
Old May 19, 2024 | 09:32 AM
Vader's Avatar
Good call on the cold start injector. It shouldn't even be active above 40°C, and should have a very short duration at 25°C. An easy thing might be to disconnect the CSI for testing. After a complete cool-down, it may take a little longer to crank to get fuel, but should eliminate the need to go WOT to get it to fire.
The standing fuel pressure reading after shut-down could also be revealing.
Old May 26, 2024 | 03:22 PM
c-137's Avatar
Car: 85 t/a
Engine: 5.0 tpi
Haven't had a chance to check much but did find a spark plug boot not fully seated on spark plug. Pushed it fully onto plug and now starts much better.
SkiingOnIce
Apr 23, 2024 05:47 PM
Stalker7d7
Dec 15, 2012 09:53 PM
Iroc-Dennis
Sep 21, 2007 06:52 PM
Beachmonkey6
May 19, 2006 04:25 PM
HalfInchWrench
Carburetors
May 4, 2005 08:43 PM
