HELP!!!!!!! idle problem
Old Mar 13, 2002 | 02:04 PM
SLOW5.0's Avatar
Howdy, This is my first post here, been lurking in the shadows for a few weeks and now I need some help.; My 90 formula is a 305 TPI 5 speed. Just noticed that it was surging at idle around and now its idleing 2300 rpm? Whats up? I just got a TPS and will put it on later. Thanks a bunch
Ron
Old Mar 13, 2002 | 02:12 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Welcome to the board.
- could it be that your throttle cable is getting stuck?
- Is your cruise cable set too tight?
- major vacuum leak (have you done anything to the car recently)?
- bad IAC or TPS.
- have you reset IAC and set the TPS voltage to .54?
That's all that comes to my mind.
Good luck.
Old Mar 13, 2002 | 02:22 PM
SLOW5.0's Avatar
Thanks for the reply. I sprayed a can of carb cleaner in the TB why I was keeping the rpms up. I was real nasty, but that was last saterday. I changed the plugs and oil also but that was Saterday as well. I will try replacing the TPS Thursday and report back. Thanks for you reply
oh ps the cable is loose and is not holding the butterflys open.
Old Mar 14, 2002 | 09:12 PM
SLOW5.0's Avatar
It was the TPS..... thXS 4 THE HELP
Ron
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
