corvette servo
Old Feb 19, 2004 | 07:44 AM
black formula's Avatar
corvette servo
What is a corvette servo, what does it do, and were can I get one. I about to change my tranny so I want to get all the parts I need.
Old Feb 19, 2004 | 08:30 AM
87kevroc's Avatar
Car: 1987 Chevrolet Camaro Z28 IROC-Z
Transmission: TeamTripp Performance
This link should be helpful.
Old Feb 19, 2004 | 11:46 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
It controls the Application of the 1-2 band and the release of it and Application of the 2-3 clutches. All that means is it REALLY firms up the 1st to 2nd shift and the 2nd to 3rd shift. It also holds the band tighter to help it to not slip.
Old Feb 19, 2004 | 07:05 PM
littlebagz's Avatar
Car: 89 Z28
Engine: 350 with ads
The servo only activates the 2-4 band. This band is activated for second and overdrive. It makes the application of the band both faster and more powerful. The reason is that the apply pistons within the servo have more surface area and receive more pressure.
3rd gear is activated by both the forward and the 3-4 cluth packs, both of which have their own apply pistons.
The servo speeds up the 1-2 shift since it applies teh 2-4 band faster and harder. THE SERVO DOES NOT AFFFECT THE 2-3 SHIFT.
A stronger servo is a reasonably priced upgrade, and you can change it with the trans in the car. (tough, but possible....)
Old Feb 19, 2004 | 10:33 PM
89rs/sc's Avatar
Car: 89 rs
Engine: 305 supercharged
Transmission: th 700
the corvette servo definetly stiffened up my slippery 2-3 shifts....
700R4/4L60E Heavy Duty Servo Kit
The TCI high performance servo kit utilizes a surface area up to 63% greater than stock providing an additional 300 lbs of 2nd gear band apply force. The TH-700R4 servo kit also eliminates the common 2nd to 3rd flare problem. This kit can be easily installed without removing the transmission or draining the fluid. Comes complete with required seals and o-rings. Note: This servo assembly is already factory installed in C4 & C5 Corvettes and 1993 - Up LT1/LS1 equipped F-body vehicles.
Old Feb 20, 2004 | 03:08 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
The servo also acts as the 3rd accumulator.
Old Feb 20, 2004 | 10:45 AM
Corvette Servo
Where can I order the servo from. If I can order it from the dealer whats the part number. And how much do they cost.
Old Feb 20, 2004 | 12:21 PM
GASGZLR's Avatar
Call Dana over at Pro-Built, or check the website cause he hooked me up for 20 bucks and it worked wonders on my 1-2 shift AND eliminated my 2-3 flare up. It took me like 20 minutes to install it without dropping the trans and made a HUGE difference.
Old Mar 2, 2004 | 09:30 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
What do you mean by 2-3 flare up? Are your referring to the rise in RPMs just before the 2-3 shift occurs?
Old Mar 3, 2004 | 08:03 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Alright guys. I have always wondered about this "corvette servo" but just thought it was just like the aftermarket ones. The ones that summitracing put out are about $80 a piece. Are they comparable to the "corvette servo"? Which is better? I am about to put in some servo's, shift kit and new torque convertor too. Just wondering. Thanks
Old Mar 4, 2004 | 10:30 AM
GASGZLR's Avatar
Dana told me that those Billet servos are overkill with a shift kit. Just get his it's like 20 bucks from probuilt.
White91GTA, yeah that's what I mean, instead of redlining then BOOM, next gear, it revs a little higher then slowly lowers the RPM's and grabs 3rd, the servo fixes that.
Old Mar 4, 2004 | 10:35 AM
White91GTA's Avatar
Engine: 5.7L TPI
GASGZLR, thank you, that is what i figured but was not sure. My car shifts at like 2000 under normal load but on the 2-3 shift, instead of shifting at 2000 it revs up to 3000 before shifting.
Old Mar 4, 2004 | 10:52 AM
GASGZLR's Avatar
Whoa thats a lot to rev up, sounds like your 2-3 clutch pack is ready to retire. The servo will put a band aid on it for now. I thought that some of the 350 TPI cars got the servo stock, maybe not.
Old Mar 4, 2004 | 09:15 PM
White91GTA's Avatar
Engine: 5.7L TPI
I do not know if it got the servo stock or not...if it did, it should probably be replaced anyways. Tranny and body have 161,480 miles on them
Old Mar 4, 2004 | 09:18 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
When you say his is 20 bucks, which one is it (1-2 or 4th)? Where do I go to get this servo? Sounds good to me.
Old Mar 4, 2004 | 11:16 PM
BottlesR4Babies's Avatar
Car: 91 Z28
Engine: 350 TPI H.O.
ebay has them for 15.99 buy it now brand new
Old Mar 5, 2004 | 06:36 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Im really glad i found this post!!!!!!!! I was just on the verge (2-3 Days) from taking my transmission out to get it rebuilt. I have a good strong 1-2 shift, and sometimes it shifts nice and hard at WOT. My 2-3 shift has about a 150-300 rpm flare and i was thinking for the last 6 months that it was time for a rebuild. Just today i was deciding wether to take it out this weekend (Friday) or wait. So that "little" rev is prolly just a flare and i can fix that with a $15-$100 servo. If this isnt beat to death-Whats involves in changing it? Man im glad i found this!!!
Old Mar 6, 2004 | 02:12 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
That link that 87Kevroc put in was pretty helpful and I just got a corvette servo off of ebay for $20.95 shipped.
Old Mar 6, 2004 | 02:22 PM
Pro Built Automatics's Avatar
The main reason GM introduced the Corvette servo was to "fix" the 2-3 flare/spinup on the 2-3 shift, with engines that had some power & using the 553 servo, this helped the 1-2 & 2-3 shifts. The Corvette servo is also the 3rd gear accumulator.
Old Mar 6, 2004 | 03:50 PM
BRIrocZ's Avatar
Car: 97 Z28
Transmission: A4
Good stuff here. I too have been experiencing that 2-3 flare up under heavy throttle in my '88. I just passed it off as slipping and time for a rebuild. I'll definitely try swapping to the 'Vette servo.
Old Apr 6, 2004 | 07:47 PM
my84firebird's Avatar
Car: 1984 Pontiac Firebird
Engine: modded 5.0
Transmission: modded 700r4
Wow I'm glad I found this. I rebuilt my trans and added a shift kit and ever since then its had an annoying 2-->3 flare under heavy throttle. I posted about it and got no response, so I've just been gritting my teeth and living with it. I'll be so happy if the vette servo fixes it......
Old Apr 8, 2004 | 10:39 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I'll be buying my tranny parts from www.bulkpart.com, they have some excellent prices. Corvette servo is 10 bucks IIRC.
Old Apr 8, 2004 | 03:42 PM
Go to http://www.pro-built.net/index.cfm?...&categoryid=146 this comes with the necessary & updated seals.
Old Apr 8, 2004 | 08:20 PM
383 rocket bird's Avatar
For the price of the servo Dana (pro built) is offering i suggest going with his stuff. He will NEVER steer you wrong and is always available on the phone for tech questions. -John
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
Dragonsys
Sep 25, 2015 03:51 PM
italiano67
Sep 22, 2015 08:42 AM
