T-5 Problems Help Needed...
Old Jun 29, 2004 | 10:37 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
I bought my RS used with supposedly 69K original miles. The T-5 in her whines a lot in 1st, 2cd, and 3rd. I will be checking the fluid to see if its low. Anyway, I have done a lot to this car and today I put on basically new stock 16x8 Factory rims wrapped with 4 new Sumitomo HTR+ 245/50/16. My problem is...the car has this kind of shake or shimmy when I'm coasting/cruising in 5th gear between 45-55 mph. The whole car seems to shimmy from the rear forward or so it seems. I thought it was an out of balance rim/tire, but it still does it after I had all the new rims/tires installed and balanced. My question is, could this be a problem in the tranny or driveshaft??? I can witness the gear shift shaking a lot, especially when it shimmys like I'm describing. 5th gear is also weird in that if I shift from 4th to 5th at anything less than 50-55 the car really seems to drag as if I shifted to early. What do you guys think is up with my car???
Old Jul 1, 2004 | 02:15 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
NObody has anything to say huh?
Old Jul 1, 2004 | 09:48 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
what are your rpms at at that speed? if they are too low that will cause that, mine does the same thing, with my cam it doesnt like to be under 2000 rmps in any gear or it does the rocking back and forth
Old Jul 1, 2004 | 11:22 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
The tach is broken...it reads about 1500 at idle and it even gets worse the faster I go...it reads almost 4000 when I'm cruising in 5th at 70mph.
Old Jul 1, 2004 | 12:33 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
How old are your u-joints?
Old Jul 1, 2004 | 01:58 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
I don't think they've ever been replaced...I bought the car when it had 68K on it, and it was bone stock. It now has 70K and I have done all the mods listed in my sig.
Old Jul 3, 2004 | 05:34 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Does it act the same in fourth gear at that speed? If so, I would suspect something in/on the driveshaft; either U-joints or tailshaft bushing in the trans.
If it doesn't act up, I would suspect the engine tuning is off...
Old Jul 3, 2004 | 11:32 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
have you tried checking if your drive shaft and rear axle are prefectly straight. lined up. this happend to me with my 84 camaro. shop teacher helped me figure it out. and it was laso making a humming nosie. but i hav an auto so it was almost all the time.
pjsparts
Oct 29, 2025 06:39 PM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
