Reading Gear Patterns
Old Sep 11, 2004 | 08:11 AM
FireBoid's Avatar
Car: 1987 Firebird, 1997 Camaro
Engine: 2.8L, 3.8L
Transmission: T5, 4L60E
I've just set up a rear end with 3.73 gearing. I used Prussian Blue marking compound to check the pattern which was recommended, but has a different consistency than the material supplied with the install kit. It's much easier to read, but the pattern shows much more gear to gear contact than the pictures I downloaded from Richmond. The pattern is very nicely centered in X and Y but the area is larger. Does this indicate a problem? Any thoughts?
Old Sep 11, 2004 | 04:43 PM
chris718's Avatar
something everyone should know about ring and pinion patterns.always rotate the pinion gear clockwise from the flange trying to establish a readable pattern.remember that if the ring gear shows that the pinion marks are closer to the back of the heel of the ring gear the pinion must be shimmed toward the back of the car becauseYOU ARE SEEING THE OPPOSITE SIDE OF THE PATTERN BECAUSE YOU ARE 180 DEGREES AWAY .i have seen many people go crazy with this and reduce shim pack and go further away from the center.think about it.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
beastin91rs
Oct 9, 2015 07:38 AM
crazynights
Aug 21, 2015 06:53 AM
mizz0313
Aug 12, 2015 06:45 AM
