700r4 to 350 turbo swap question...help??
1 Post
Car: 86 2wd
Axle/Gears: 2:73 open (for now)
bought my camaro without a motor and tranny....it originally had the 700, but alls i have to put in it is a TH350-
....on my transmission, i'm missin something....i need the piece connecting the "bolt thing" that comes out of the side of the transmission that connects to my linkage....i have the linkage that goes from the frame to transmission, but im lackin the piece that connects the two together....any ideas???.
...i'm also lackin the bracket that bolts on the intake (i think thats where it bolts) for the kick down cable to push into.....anyone have one of these??
thanks
klambert@cebridge.net
-bigarmzz-
thanks
-bigarmzz-
1 Post
Car: 86 2wd
Originally posted by transambill
I have both if ya need them.
ya got the kick down bracket that bolts on the manifold????
man if ya got one of these, let me know....i got a chrome one at advance auto, but the hole is too small for the kick down cable to fit into.....
let me know
thanks
-bigarmzz-
Car: camaro 1985 iroc
Engine: 350 4bbl
Transmission: th350
HEY - I JUST NOW, AND I MEAN MINUTES AGO DID THE SAME SWAP IN MY 85 IROC. THE TH350 IS SHORTER THAN THE TH700, HOW DID YOU SOLVE THE DRIVESHAFT LENGTH PROB?
MIKE
MIKE
1 Post
Car: 86 2wd
MIKE
MIKE
well, so far i havent solved jack sh*t.
...i'm trying to find a longer drive shaft than what i need, and get it cut down at a local shop.....i guess you can shorten one, but to "lengthen" one is either impossible, or extremely expensive.....
anyways, ya got to first find a th350 slip yoke that will fit your tranny...i tried three diff 350th slip yokes til i found one that fit...so i'm pretty sure there not the same......thats first
-bigarmzz-
Car: 91 Firebird Formula
Engine: ZZ4 fast burn with TPIS mini ram.
Transmission: Viper T10 6 spd.
Yes I have the bracket for the throttle cable and kickdown cable.
I'm currently parting out a 86 Firebird thats a 305 carbd car and it has the bracket you need. As far as the yoke go's, the 700r4 and turbo 350 use the same yoke.I've done 3 700 to T350 swaps and they all use the same yoke. Just remove the yoke from your factory driveshaft and install it on a 3in. longer driveshaft.
1 Post
Car: 86 2wd
i've heard the slip yoke is "suppose" to be the same....but the 700 slip yoke wont fit into my TH350 tranny....
i know its "suppose" to...but it dont...
let me know what you'd have to have out of your brackets...
thanks
-bigarmzz-
$20 shipped for the shift lever and kickdown bracket. Have you got a Drimmel? If I already had a chrome bracket I think I would try enlargeing the hole to make the bracket work unless you can return the chrome one and get the correct one for around the same price.
1 Post
Car: 86 2wd
ya dont have the L-shaped linkage that goes between the frame, with the spring thingy on it, that attaches to the transmission for a TH350 do you???
mine is for the 700, and wont fit in the holes on the u-shaped bracket that attaches to the transmission
-bigarmzz-
