How do I know if its a WC T5?
Old Sep 5, 2005 | 10:36 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'm trying to find one and I see a few cheap firebirds for sale that I may buy and part out if it has the WC tranny. Any ideas on what years to get or to avoid?
Old Sep 7, 2005 | 07:05 PM
Russ-So Cal's Avatar
W.C. came on 1988 and newer. That doesn't mean someone didn't change out a W.C. for a non-W.C. Probably the quickest way to tell is to pull a drain plug. If atf comes out you probably have a W.C., if gear oil comes out, it's not W.C. If someone is determined to rip you off they can always put atf in a nonW.C.
There are physical differences, but I'm not familier enough with them to try to describe the differences in the cases on the outside.
