changing rears will it work?
Old Sep 17, 2005 | 10:11 PM
package's Avatar
Car: 1987 camaro lt
Engine: 305 4 barrel
Transmission: th 700r4
i have a 87 camaro with a 10 bolt drum with 273 open.i found a complete rear out of a 84 firebird witha 10 bolt disk 373 ration limited slip.what is involved with changing the new rear over to drum brakes from what ive read its just switching the components.is this correct? Also i would like some opinions on whether or not anyone thinks this rear will make a big improvement over the crap that was on there.can anyone pont me in the right direction on having my prom burned to accept the changes and shut my damn check engine light off
Old Sep 18, 2005 | 12:43 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I'm not too sure about the brakes, but I think you just have to switch the components, including different brake line fittings. I did the same swap as you want to .. 2.73 dif. to 3.73 posi .. and I really liked the difference. Also, if your car is carburated, you don't have a prom, and changing your rear end won't affect the tune of your engine.
Old Sep 18, 2005 | 07:10 AM
package's Avatar
Car: 1987 camaro lt
i have a computer controlled carb.i have a cal-pak error comunication code in the system.chevy said it was from the previuos owner when they changed the engine they didbt have the prom redone.
Old Sep 18, 2005 | 07:33 AM
ede's Avatar
ede
you want to switch the drums you have to the disk rear? i think all you'd need to do is just unbolt backing plates and swap. you ought to be able to do it without unhooking brake lines.
Old Sep 18, 2005 | 07:43 AM
package's Avatar
Car: 1987 camaro lt
you just saved me a bunch of work,thanks a million.ill let you know how it comes out
Old Sep 19, 2005 | 04:45 AM
darrells3rdgen's Avatar
Car: 86 trans am
Engine: 350 cid from a 69 chevy truck
Transmission: original 700r4
I may be wrong but rear disk brakes take less fluid pressure than drum brakes do. so you might want to get the pressure valve off the car with the disk's. its mounted under the brake mastercylinder.
Old Sep 19, 2005 | 06:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the following link:
https://www.thirdgen.org/techbb2/sho...hreadid=321622
Why not simply swap rear ends?
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
jharrison5
Aug 19, 2015 05:53 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
