700R4 swapping questions.
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
I've done this before with the same tranny that was rebuilt but now I can't wait for that and I'm getting a 700R4 from a reliable person. I'm kinda iffy on what years/models I can get a 700R4 from. Does the v6 make a difference. TPI vs TBI any difference in there. Output shaft splines and difference in there between the many years. How about the torque arm? Anything change with that?
PS If everything goes to plan than the camaro will be back on the road! woohoo.
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The decent ones are '88+... You need to get one for a V8, the V6 ones are not only different internally, but also have the wrong bellhousing. TBI/TPI doesn't really matter..
Any problems with the electrical connections between those years. Speed sensor?
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
I believe it was 87 and up that received the improvements over the previous model. I have a th700 in my 87 and its been great. Shifts nice and firm.
Yeah the speed sensor is different than oth older tranny. Just a simple swap of the newer sensor and the older gear and no problem.
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
