your thoughts
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
your thoughts
finally got the ol wrecked IROC back together enuf to drive,with both wheels off ground,both have quite a bit of runout(wobble)if rear end is bent,then have to use another housing,could only the axles be bent or ?????????
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
If the rear end housing is bent enough to make a wobble the axles are bent too.
If its that noticeable I would pull both of them and check them out as well as the posi unit for damage.
later
Jeremy
later
Jeremy
Elephantismo
Feb 13, 2019 12:51 AM
Damon
Sep 26, 2015 04:29 PM
