rearend
Old Jul 8, 2008 | 12:27 AM
Rydda's Avatar
Car: 89 Camaro, 93 Cadillac Deville,
Engine: 355 in the camaro, 4.9 in the caddi
Transmission: 700R4 in the camaro
Axle/Gears: stock on both
rearend
what hp/tq levels are dangerous for the stock 10 bolts in the third gens. the car has a 700R with a 2800 converter, and the rear gear in my car i believe is a 2.83. also is there anyway to beef up the rear end to withstand more power. i know i can drive around with the current setup with the engine i am putting in it, but im afraid to really get on it because i dont think the rear end will hold for long if i do. here is basically the setup that i have.
http://www.carcraft.com/techarticles...ne/index1.html
there are a several parts that are different, but all the parts that make power are basically the same. i have the vortec heads, and the same cam they used, the 1.6 rockers, and i have the 750cfm carb. the only things that might make a little difference is that my block is only .030 over where theres is .060. and my headers are 1 5/8 where they used
1 3/4.
Old Jul 8, 2008 | 06:34 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: rearend
Only thing dangerous to the 10-bolt are dumb drivers.
Old Jul 8, 2008 | 06:50 AM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
Re: rearend
At that power level you should be fine, but if you want to beef it up the same things you would do to any other rearend would work. Have the axle tubes welded up change the gear and dif to better ones and use a solid pinion spacer instead of a crush sleeve. Buy a aluminum dif cover that has the preload screws in it for the caps. There is also an axle shaft kit that will work on some covers to help strengthen the rear axle tubes.
Old Jul 8, 2008 | 01:04 PM
Rydda's Avatar
Re: rearend
so would i be looking at $500-$600, or would it be cheaper to go out and buy a direct fit 9"
Old Jul 9, 2008 | 03:14 PM
rhead007's Avatar
Car: 73LT,81Z,85Z
Engine: 350 350 350
Transmission: 700r4 700r4 700r4
Re: rearend
can these posi rears be rebuilt i got one a gut blew with a 305 swap i got the core its got little discs that look like the ripped to shreds this was a 4 wd if that matters any help would be appereciatted thanks
Old Jul 10, 2008 | 06:02 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: rearend
the only thing? How about high hp and lots of traction?
Old Jul 10, 2008 | 07:37 AM
DJP87Z28's Avatar
Re: rearend
That still is your problem and being dumb enough to think a stock rear will be all right.
Old Jul 10, 2008 | 09:43 AM
3rdgenmaro's Avatar
Car: 88 IROC
Re: rearend
LOL! I got ya now
Old Jul 11, 2008 | 04:15 PM
mikes88iroc's Avatar
Car: 1988 IROC
Re: rearend
Guys: Different subject need some help. I have an 87 Z with a standard 5 speed and 305 TPI. The garage guys say the rear axle at 179,000 miles should be replaced. Will the rear end from an 1988 IROC with automatic trans and 350 TPI work on my 87? I am not so much worried about performance gain or loss, just trying to keep my old girl on the road....
Old Jul 11, 2008 | 04:43 PM
DJP87Z28's Avatar
Re: rearend
It would be a direct bolt in if the price is right. Could be a 2:77 or 3:27 9-bolt but that is a guess right now.
Old Jul 11, 2008 | 04:58 PM
Car: 1988 IROC
Re: rearend
Thanks for the reply...
Mike
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
86White_T/A305
Aug 17, 2015 12:16 AM
