700r4 reverse input drum clearance
Old Oct 3, 2008 | 06:09 PM
mmather1's Avatar
Hey, I'm rebuilding a 86 model 700r4, and my reverse input drum clearance is to high i think. it is .090". What is the clearance supposed to be ? My 4 steels are .075, my frictions are .068 , my backing plate is .260" and my snap ring is .061. This is the early trans without the aux valve body, and its a steel piston. Thanks.
Mike
Old Oct 3, 2008 | 06:17 PM
gmpptech's Avatar
Re: 700r4 reverse input drum clearance
Should be .040 to .076" Will need thicker backing plate #2
Old Oct 3, 2008 | 07:27 PM
mmather1's Avatar
Where do I get one of these? order through a local trans shop? i have another core but it has the same one in it
Old Oct 3, 2008 | 08:08 PM
mmather1's Avatar
Also in my core i noticed that the reverse input drum has a bellville plate on the very bottom and the one im rebuilding does not, could i use that to take up some of the space? or is there a reason why that is not in there?
Old Oct 4, 2008 | 06:07 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
.050 i my preferred target clearance.
Old Oct 5, 2008 | 04:39 PM
gmpptech's Avatar
Get the plate at your local chevy dealer
It should have the belleville spring in there
Old Oct 7, 2008 | 07:45 PM
Pro Built Automatics's Avatar
If the drum has a steel piston, it will need a waved steel on the bottom, then clutch, flat steel, etc. DO NOT use the Belleville on a steel piston setup. The waved steel will reduce the clearance. Dana
Hotrodboba400
Dec 10, 2019 07:07 PM
devilschariot
Feb 25, 2016 03:08 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
