converter question
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
converter question
how can u tell if your torque converter is lockin up? My gas mileage has dropped steadily over the last 2 months...its not sensor fuel or igntion related...the tranny does need to be serviced...but if the TC wasn't locking up that would kill my MGP right? so how can i tell if its locking up? Thanks!!
Originating member of the SJNEP Crew
Member of the Jersey Fbody Crew(JFA)
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Tony
At freeway speeds, when at light throttle you should be able to touch the brake pedal lightly (enough to make the brake lights come on) and watch the tach rpm's go up 150 or more rpm, and as soon as you let off the brake the rpm's should drop back down.
Hope This Helps!!!
Hope This Helps!!!
Car: 2018 Camaro SS
<font face="Verdana, Arial" size="2">Originally posted by Pro Built Automatics:
Hope This Helps!!!</font>
1992 Trans Am
May 10, 2023 07:19 PM
