Stock diff width?
Old Mar 9, 2009 | 08:11 PM
oneday's Avatar
Stock diff width?
Im swapping diffs in my 83 camaro and was wondering what the stock width of the diff was?
Old Mar 9, 2009 | 09:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Stock diff width?
Axle flange to axle flange?
A diff swap isn't that easy. Third gens use a torque arm suspension and installing some other junkyard diff is difficult unless you find some way to attach the torque arm or eliminate it by changing the rear suspension design.
Old Mar 9, 2009 | 10:37 PM
oneday's Avatar
Axle flange to axle flange would be great.
i wont to know for a starting measurement to plan out what i wont to do with the suspention, i would like to stay with the stock set up. but would like to mini tube it. i would like to know exactaly how wide the diff is to start and add things up from there.
Old Mar 10, 2009 | 04:10 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
stud on the rotor to rotor is roughly 62 inches.
Old Mar 10, 2009 | 03:51 PM
Shagwell's Avatar
Car: projects.......
that's a bit hard to decipher. - I'd reccomend using the search key and doing some research on what you're looking to do.
With stock suspension, the only "mini-tub" type job that can be done is most squaring the stock wheel wells to allow a little more room. To fit wider than a 315 tire you will need to alter the suspension to clear the tires. The stock lower control arm mounting location. - All that said, there are plenty of drag radial class cars running low 7's in the 1/4 on stock suspension with hammered/slightly re-worked wheel wells and 285/65/15's.
If you want more tire than what can be fit with minimal mods, you might as well back-half the car and putting steam rollers under it.
Genopsyde
Oct 7, 2015 08:35 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
