700r4 problems. Reverse and P
Old Feb 20, 2011 | 10:32 AM
mikiman's Avatar
hello from Spain. Me English it's not very good. I hope you understand me.
This morning I have problems with my 1990 3.2 V6 firebird, with a 700R4. The reverse gear doesn't work, it's like in the Neutral. The rear lights works, but the car doesn't move. The P doesn't work good also. It's like if a gear was actuating and the car moves when I accelerate.
I have put off the console looking for broken wires or conexions, but it seems to be ok. Under the car all seems ok. I thought that some silenblock could be broken, and that the motor or the bar have changed their position, but they are in their place.
I changed the transmision oil and the filter, a year ago, but I put a little more over the mark.
I have read the services codes, and I have 4 :
22--steering column resistance too low
32--grounded 36 VLR to deployment loop
35--discriminating sensor open
13--oxigen sensor circuit
anybody have any idea ? It's very dificult open the gear box to look for the reverse control valve ? I have only open a manual box, but never automatics
thanks a lot
Old Feb 20, 2011 | 10:53 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: 700r4 problems. Reverse and P
Is the shifter cable mount ok inside the console??? I'd start there....
Old Feb 20, 2011 | 12:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Sounds like a shifter cable problem - replace (get GM if possible, others no good).
Old Feb 20, 2011 | 01:09 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
newbie did you talk foreign english in text? haha.
Old Feb 27, 2011 | 03:18 PM
mikiman's Avatar
I saw the cables in their place, and in good conditions ( I think they are the park and shifther cable ). I have take off the pan transmision oil, under the transmission box, and when I change the shift position, I see how the shifter cable moves the carrier plate, and all the gears seems like works good.
But I put the car in a elevator, over the floor, to see how the wheels moved, and when I put the reverse, the wheels did a "clack", but didn't moved. And when I put the N, the wheels moved like in D, and the P was OK ( I had a mistake in the first message ).
Any idea ?
Old Jun 3, 2011 | 03:11 PM
mikiman's Avatar
Re: 700r4 4L60 problems. R and P.***check ***** ?
I have open the tranny, and I have seen something strange with the check *****. There are a check ball case with a little damage, like as the ball had too much travel and the ball consume it ( sorry, the photo it's very bad, I will do it better ). And with the gasket it happens the same. I have read the manual service, and says that it's the "55F #8 check ball (2nd /1-2)".
It's posible that I was losing fluid presion for there ?
Uploaded with ImageShack.us
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
