What years make an E.Z 700r4 swap in 84' 305?
The transmission case has stripped bolt threads, bad leak, now its sticking and slipping. No doubt,it need to be replaced.
I know jack about transmissions, except that I cant afford a new/remanufactured one.
Will an 85' 700r4 out of a Corvette fit?
Which Chevy years and models have the same 700r4 as the one in an 84 camaro?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: What years make an E.Z 700r4 swap in 84' 305?
You need a 700R4 from a Camaro or Firebird - they are the only ones with the torque arm mount. Prefer 1988 - 1993, there were internal changes in mid-1987 trannys that make them better/stronger. Later years have electronic speedo, you have cable driven - just need to swap your tailshaft housing onto the newer tranny.
Fast355
Dec 2, 2016 06:33 PM
