axle compatability
Old Jun 26, 2011 | 11:25 AM
overboost07's Avatar
Car: 1988 pontiac trans am gta
Engine: 305 tpi
Axle/Gears: factory
axle compatability
Ok I have an 88 gta which I have put a 96 firebird formula rear end in, its a 6 speed 3.42 rear end, well the axle is bent. My brother has a rear end out of a 1999 v6 5 speed camaro. Are those axles interchangeable?
Old Jun 26, 2011 | 12:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: axle compatability
Maybe but those are both fourth gen axles. GM may have changed the axle length during the production run. There's a good chance they're identical, but you'll have to research fourth gen axle lengths.
If you're asking about the entire differential, yes they can be swapped.
Old Jun 26, 2011 | 12:29 PM
Engine: 305 tpi
Axle/Gears: factory
Yea just the axle, the part where it unclips from the differential and slides out. I wasn't sure because I heard the lt1 cars rear end was a,little wider than the newer fourth gens. He said his was a 28 spline, this is my dd so I have to get it fixed quick. If their interchangeable then I just have to go get it and put it in.
Old Jun 26, 2011 | 08:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
All the 10 bolt axles starting in 1990 are 28 spline.
Just did a quick internet search.
93-96 f-bodies use 32-1/8" axles
98-02 f-bodies use 32" axles
I have no idea why there isn't a listing for 97 but the difference between the 96 and 99 is 1/8" which means it's probably not advisable to do a swap. You can always ask on a fourth gen site if such a swap exchange is possible.
Old Jun 27, 2011 | 02:01 PM
Engine: 305 tpi
Axle/Gears: factory
Thanks iroc!
Old Jun 30, 2011 | 04:36 AM
gosooners's Avatar
Car: 91 Z28 convertible
Engine: 5.0 TPI
Axle/Gears: 4th gen 3.23 PBR
When you get post 96 axles some may be traction control while 93-96 will not be. I did alot of searching for my axle swap and many companies recommended the same pn#'s for any year - difference was the TC's vs. non-TC. If you have TC axle, ensure you replace w/ TC compatible axles, otherwise any non-TC will do. I had no problem w/ my axle swap for a post96 non-TC rear.
6speedIROC
16
Mar 15, 2023 08:33 PM
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
