What is needed when switching to a TH350?
Old Oct 17, 2011 | 08:18 AM
MacsIROCZ's Avatar
Car: 86 Iroc-Z28 Camaro
Engine: 383 SB
Transmission: TH350
Axle/Gears: Stock disc brake 3.43
I am beginning a motor swap on my 86 Iroc z, I am dropping a 383 Stroker in with a rebuilt TH350... What all am I going to need for this change in tranny? I was told I have to do something with the kick-down cable? Or buy a new one?
Thanx Guy
s
Old Oct 18, 2011 | 11:48 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Re: What is needed when switching to a TH350?
Trans, driveshaft, torque arm, crossmember.
Torque arm is the biggest of course since it will no longer mount to the trans. Buy something like this which relocates the torque arm to the crossmember.
http://www.spohn.net/shop/1982-1992-...nsmission.html
Old Oct 18, 2011 | 06:32 PM
91CamaroRS/SS's Avatar
I actually recently have done that, and the only thing i had to get new was a cross member. And if you have any fab experience or know of anyone who does, take off your torque arm mounting hardware and have someone mount that to your new crossmember. And shifter linkage. Be careful not to strip the holes for the linkage on the tranny itself..then you will have a whole lot of things to play with. Trust me I know from experience. I had to get a piece of angle iron, drill holes from my pan bolts, get tons of washers, and drill holes to match my shifter linkage. It can be done..but my oh my
Old Oct 18, 2011 | 06:37 PM
OOps. As long as its a Long Tail 350 you wont need a driveshaft**
Old Oct 19, 2011 | 06:17 AM
MacsIROCZ's Avatar
Engine: 383 SB
Transmission: TH350
Do I measure my tranny from front to tail or what? is that how I get the length? I know the short is like 5" vs. the long is 9" right?
Thanx Rob that was a nice site link. I have been looking @ BMR but that is everything all in one is it not?
Old Oct 19, 2011 | 07:20 AM
Your gonna measure from where the tailshaft bolts onto the end of the tranny. Yes longs are 9" and I have heard that there's medium abd short tail shafts that are 5" abd 3" but I think that's hogswash.
Old Oct 19, 2011 | 10:03 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
th350s come with 9, 6 & 4 inch tailshaft lengths. the 9 inch will allow you to re-use your driveshaft if it originally had a 700r4. not sure if you can re-use the 4-speed o.d. shifter? i used a z-gate. not sure on speedo compatability either,...i never hooked mine up. going with a suggested crossmember like above is probably the best way. i modified mine to be able to attach the torque arm mount. not pretty, but it works better than it looks. not seen in the pic below is a hole drilled straight down on the end of the piece of angle. i also drilled a corosponding hole in the transmission tunnel. then i conected them with all-thread securely. with the all-thread i can slightly adjust the pinion angle & it also supports the end of the bracket. crude,...but its been working fine for 2 years now.Name:  0131163037_01.jpg
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
Fronzizzle
Aug 9, 2015 01:15 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
