Transmission Swap 700r4 to Turbo 350
Car: 1986 Chevy Camaro
Engine: SB 383 Fuel injected
Transmission: Powerglide
Axle/Gears: Currie 9 inch 4.56 gears
This is for a 1992 Camaro 350 TPI Z28 and we are swapping in a T350 to replace the 700r4. We have already ordered a custom crossmember and driveshaft so thats all taken care of. Heres the problem, the kickdown cable doesn't fit. Is there a universal kits online that someone sells that I can purchase a Kickdown cable? what can I do to make this work? any suggestions or links to other sites would be greatly appreciated.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Transmission Swap 700r4 to Turbo 350
On a TH350 it only makes the trans down down a gear.
If you want to manually shift the trans down when you want to accel you don't even need it
If this car was for me I wouldn't be asking this question I woulda converted the trans to a manual Valvebody to completely eliminate all of this but this car is for my friend he doesn't want that i already fixed the problem too I just ordered a kit from summit
