Aluminum Driveshaft Advantages/Disadvantages?
Car: 1985 Pontiac Trans Am WS6
Transmission: 4 SPD AUTO Borg Warner 9 Bolt
Thinking of purchasing an aluminum driveshaft to replace the stock steel one (found a fairly cheap one in good shape).
Other than weight savings are there any other advantages?
As far as disadvantages do aluminum driveshafts break easy?
Can aluminum take the consistent torque of the stock 305 TPI?
Re: Aluminum Driveshaft Advantages/Disadvantages?
A search should find you a ton of info (as on most questions). The following link will start you off:
http://ws6.com/mod-1.htm
Best of luck on your decision,
JamesC
JamesC
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My virus scanner picked up a malicious script on that page.
I hate seeing the claims on how an aluminum shaft reduces vibrations. They do but if you have your steel driveshaft balanced or have a new better steel shaft made, it will be balanced, you should see the same claims.
OEM aluminum shafts are not very strong. The biggest advantage is the weight saving. I run a 3" x .083 steel shaft on my race car with 1350 yokes. Never had a problem with the torque I'm making or for the brief period I'm at 150 mph. However to be on the safe side, I also have front and rear driveshaft loops.
If price was no object, I'd get a carbon fiber driveshaft.
Engine: 4++,350 & 305 CIs
Def advantages to using aluminum.
I have seen CF drive shafts get longer and destroy itself and a transmission!
No matter what you choose, read up on them as much as you can and pick what's best for your car.
Google "driveshaft Critical speed", its something your shaft needs to be able to handle if you plan on running them hard..
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Here is a little write up on drive shaft, this is the company I bought mine from
http://www.driveshaftspecialist.com/...le%20cars.html
advantage, advantages, aluminium, aluminum, break, carbon, cost, driveshaft, driveshafts, easy, fbody, price, shafts, steel, tpi
