700r4 1st gear shifts late and slow
Car: 90 Firebird Restored
Engine: 3.1 prepping a 5.7 TPI for it
Transmission: 700R4 prepping a 700R4 for it
Axle/Gears: 323? 342s soon
Okay first off I have no Knowledge of how transmissions work or anything I am new to this.
Ever since I owned my 1990 3.1 firebird 700r4 138k on the engine, it always seemed first gear shifted hard. I thought this was normal but I tend to notice it takes too long to shift when I step on it.
I tried testing my 0-60 time tonight and according to the internet it does it in 9.4 seconds. I floored it and it took over 12 seconds. it stayed in first gear till 40mph and stayed at 40 for at least two and a half seconds before jumping hard into second. Even when I dont floor it it seems to shift this hard out of first. Is this normal? When I shift the gears manually it goes through them as soon as i move the shifter, no lag. Any help would be appreciated. I also Plan on doing an L98 swap next winter but I would like to improve it if I can.
Re: 700r4 1st gear shifts late and slow
The V8 won't bolt up to a V6 transmission because the bolt patterns are different between the V6 and V8 engine blocks.
Yeah another reason why I am considering Keeping my V6. just read an article about all kinds of things I can do that will satisfy my lust for power.
Scratch keeping the V6, just got an L98 and 700R4 at a swap meet today 112k on them all set now
You'll at least need to swap the extension housings between the V6 and V8 transmissions in order to have a place to bolt the torque arm to.
plan on keeping everything after its swaped incase I want to make it original again. Got them out of an 86 vette that was junked I just need the other half of the wiring harness and an ECU.
someone972
08-30-2015 12:52 AM
