350 turbo transmission swap and spedo not working?
Car: Camaro Z28
Engine: 5.7L 350 V8
Transmission: 350 turbo transmission
guys after they swapped the tranny for the 350 turbo my spedo isn’t working what’s the workaround for this does anyone know the best way to fix it?
Car: Camaro Z28
Engine: 5.7L 350 V8
Re: 350 turbo transmission swap and spedo not working?
It’s the original cable and it’s a tpi
Car: Camaro Z28
Engine: 5.7L 350 V8
Car: Camaro Z28
Engine: 5.7L 350 V8
Also It’s an 89 Camaro z28 with the 5.7 350
Should be 7/8 fine thread. You might want to measure your cable housing threads and verify the threads with the seller.
https://m.ebay.com/itm/Speedometer-G...%257Ciid%253A1
Car: Camaro Z28
Engine: 5.7L 350 V8
Perfect so just changing out this head should work? The old teeth should be fine?
Car: Camaro Z28
Engine: 5.7L 350 V8
I WAsnt sure if I needed to change the actual gear with teeth or if it’s adaptable
Car: Camaro Z28
Engine: 5.7L 350 V8
The rear end tires are a lot bigger they are 275/35 r15s but it shouldn’t throw the spedometer off that much should it?
You can see how far off it is here
http://www.tciauto.com/tc/speedometer-gear-calculator/
