700r4 upgrade
700r4 upgrade
yes im about to change heads cam and intake out on my 87 iroc and dont know where to go tranny wise will my 700r4 be able to handle new modsplanning on making 400-450hp
Re: 700r4 upgrade
Depending on the mileage on the transmission, 400-450 HP will eventually burn up the stock clutches. You will want to either rebuild it or replace it with a stronger built transmission. And also, if your thinking on replacing the 700r4 with a T5 manual, you will run into the same issue with it not holding up long under more power. HP cost money and the more you mod an engine the more money it's going to cost in other area's. Like say, the rear end for example, and then maybe brake upgrades, and then if you haven't already, sub frame connectors. Think this through before you spend a bunch on just the engine.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 700r4 upgrade
With the power goals you have in mind, swap out the 700r4 for a TH400 with good clutches, a shift kit, and decent converter. Save the money you will keep in your pocket from SEVERAL failed 700r4s and buy you a Strange 12 bolt or Strange 9" rear-end housing as your 7.5" 10-bolt will soon fail as well.
Re: 700r4 upgrade
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 700r4 upgrade
Guys are spending wads of cash building 4L60E/4L65E/4L70E (very similar to a 700R4) transmissions and destroying them in no time in trucks and swapping to 4L80Es.
Will also add that I pulled the POS 4L60E that went out at 38K miles behind a stock 350 and was upgraded to 4L65E spec out of my Express van at 78K miles and put a stock 100K mile 4L85E into is place. The 85E has close to 150K on it now and I beat the crap out of it and it is still going strong. FWIW the 4L80E/4L85E is basically a TH400 with an extra planetary set to give it OD and electronic controls.
I actually just swapped a 3rd gen to a TH400. The TH400 itself was built to withstand an 600+ HP engine. The swap was less than $2,000 start to finish. Car has a Hotcam and 2.73 gears, so no real reason to run an OD, especially with the 9.5" 2,800 stall converter. The "built" 700r4 died twice in less than 10K miles on this car and the owner was fed up.
Re: 700r4 upgrade
You do realize a TH400 was the predecessor to the 700r4/4l60 and with much of the same parts and upgrades to the 700r4 most of which was overdrive. Now as for your comment about spending $6K on a rebuild, yes you can spen a lot if want to, or you can spend $1000 from Dana at Probuilt Automatics that will support 700hp and do it yourself. If you or somone you know happened to have an issue with a "built" transmission, unless you yourself built it, how do you know what or was not built into it. Don't go around bashing something that you may have had an issue with, that probably wasn't built to begin with.
Re: 700r4 upgrade
yes I know it is a chain reaction with upgrading and the $$$$ side of it I already have headers exhaust sub frame connectors and tower brace I need a new torque arm and have just got a lt1and rear end out of a 97 z28 the guy owed me not sure how helpful it will be but all in all I have had the car for a yr and just figure I can keep dreaming or just bit the bullet and jump in that way I'm not here a yr from now saying oohh I want to start on modifying my car yall know what I mean just wondering if I can keep my over drive trans or not because I do drive it back and forth to work on Monday and back home on Friday about 70miles one way and thanks everyone for input I appreciate it
Re: 700r4 upgrade
That's a nice looking Camaro. If you don't beat the snot out of the tranny, it should last a little while until you decide what way to go with it. I ran mine for a summer with close to 500 hp at the crank, and when i tore down and rebuilt the tranny, the clutches and the band were burnt and slipping some. I also had a Transgo kit in the valve body at the time. Now I have a Probuilt Automatics kit in the 700r4 and it works great. A lot more line pressure and great clamping on the clutches.
Location: *member since 1999, I think - just can't remember my old name, and the big site crash...*
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Re: 700r4 upgrade
My old/previous GTA had 450 hp. I had a Rossler-built trans from Carl Rossler Transmissions in Girard (Youngstown OH)
It lasted years, lots of time on the track and street. Zero failures.
Was about $1,800 but that was 20+ years ago. He's still around. But prices are surely more.
I hope this helps.
I hope this helps.
Re: 700r4 upgrade
yes that's what I was hoping to be able to beef this trans up or get one already built just wasn't sure about this model holding together but from what yall said I think I will give it a run with a new built 700. also will this rear end I have from a 97 z28 be any better than the one I have in it already or be the same. and again thanks so much for input greatly appriciated
Re: 700r4 upgrade
The 97 is a little wider rear than the 9 bolt in your IROC. It will swap out okay, but a lot of opinions out here are that the 10 bolt 4th gen isn't any stronger than the BW 9 bolt. 28 splines are about the same on each. You probably have a 3.27 gear in the 9 bolt, this is all assuming you have a true IROC, otherwise you may have a 10 bolt underneath. All depending on your engine build and RPM range, a 3.70 gear in the 9 bolt or 3.73 gear in the 10 bolt might be a better fit.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 700r4 upgrade
For the record, my 700R4/4L60E/4L65E failures have not been slipped/burned clutches and bands. They have been broken hard parts. Input shaft/drum shattered, broken planetary sets, and even stripped the case lugs off the case that hold the low/reverse clutch pack. When you start making any kind of torque and have traction the internals become fairly glass like.
Re: 700r4 upgrade
That may be all true. Also don't think that a TH400 can't be tore up. But the Op already has a transmission. Its a 700r4. If he wants to build it, for $1000 he can build a transmission that will hold extreme HP and still have overdrive and a wider gear ratio. It's his choice. There are plenty of people running a built 700r4 on the street and strip with out any problems.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 700r4 upgrade
Re: 700r4 upgrade
Well here it is Fast guy. I had a '73 Grand Prix in 1976 with a hopped up Pontiac 400 and a TH400 behind it that got squashed. They can break also. To get back to topic, the OP wants to know if the 700r4 will handle his HP goals, it will stock for a while. If he wants to build it to handle more HP, he can without breaking the bank. He never mentioned making his Camaro into a full out drag racer. He uses it as a daily driver. Now you can have all the opinions you want as to what YOU think someone should do, but there is absolutely nothing wrong with a street/strip built 700r4. Do some research on here and find out what others are doing with their 700r4's. So why would someone want to run 3200rpm's in drive depending on their rear gears to work on a freeway?
Re: 700r4 upgrade
Having seen some failures.... you basically have to replace everything but the case with aftermarket. And at that point you can't really call it a 700R4 anymore. It is a 700R4 clone with no GM parts inside. It's like saying you have a 350 small block - but you have replaced everything but the block. Yeah it's *of the same basic design* but is it what the engineers at GM designed? Sort of. And then to make real power you get a Dart block and have no GM parts at all.
GD
GD
Re: 700r4 upgrade
GD
GD
Re: 700r4 upgrade
Mine blew the retainer lugs off the forward clutch snap ring in the drum. I'm told "fatigue"..... It's still weak aluminium to me if it fatigues behind a 190 HP LB9. To me that means the drum is a poor design or garbage casting. Only mod to the car was 370 gears. Trans was original with 150k.
Then you have the sun shell known weakness.... There isn't that many parts inside these transmissions. The sun shell and the main drum - that's like 50% of the bulk inside there. And all the stock clutches are weak. It's not a bad trans but the guts weren't meant for drag racing.
GD
GD
Re: 700r4 upgrade
I think I'm buying a built one after hearing from every one and not gonna try and make mine work with my local trans shop building it can anyone recommend a company building badass 700r4s
Re: 700r4 upgrade
Here are a couple; http://www.monstertransmission.com/7...ts_c_3792.html, https://www.transmissioncenter.com/product-category/gm/ Or if someone else has any ideas.
Re: 700r4 upgrade
I'll say it again, call Dana at Pro-Built Automatics and he will get you exactly what you need. I'm pretty certain he is selling whole units again, built to his tested and tried specs, as well as selling all the parts you need to build one yourself if you want to. I do not have experience with Monster, but I can say with confidence you'll find a lot more negative reviews on Monster than you ever will on Dana.
Re: 700r4 upgrade
Re: 700r4 upgrade
to buy all the after market hard sold today. will run over $2000.(just hard parts) knowing a lot of guys would never pay that for just parts..some guys will just add a few parts. and leave the other parts out saying ya don't need them.. put 700hp to it and see if it lives.add a trans brake..add $400.. below every aftermarket part sold..installed...
trans brake installed
ya get what ya pay for..
700R4 close ratio (no RPM drop from 1st to 2nd..2nd to 3rd) 6 pinon planet..$600
hardened input shaft and front drum(bolt together) no snap ring and holds 9 clutches..$580
GM 5 pinon rear planets..shop for a good price
billet pump gears. $180
all thrust bearings
the case is made By GM.
way to spendy for most... I would do a trans brake.th400 with a gear venders over drive. for the same price I spent on this one
moroso did the trans pan. for me..as the ones they have made in the past did not fit..so they sent me one for free.. for pointing out the bad pans...tried a few..
all thrust bearings
Re: 700r4 upgrade
Call Cahall Performance Trans. He will take care of you. He has 4l60es in the 9s in 4500lb cars. That is his stage 3. He offers a stage 4. He can build you one to hold anything you want. Prices are fair. I paid around 2200 complete. Will handle 1000hp.if you have an old moroso pan btw send it in. I did and Ray took care of me and sent me a new one for free. He recommeds protorque convertors if your in the market.Stay away from Monster trans if no one has told you already.
Re: 700r4 upgrade
Dana is a one or two man show. He's on a lot of forums giving great, free advice. He handles his own phone calls, and calls everyone back (sometimes even if you don't leave a message). He's essentially a legend in the auto trans industry. This keeps him super busy. I know he has had problems with his website in the past. If you want his info and product you're best off if you call and leave a message. He will call back even if it takes a day or two. You can help speed the process along by having all of your internal engine and drivetrain specs ready as well as be able to explain your driving style, intended use of the car, etc. You'll be impressed with how he puts all of that data into a specific-built kit, or trans, just for you. From personal experience, his support before, during, and after the sale is second to none.
Re: 700r4 upgrade
this is also a top guy..
full price brake down..and or upgrades.. has parts in stock...or can be in stock with in a week..
he will also sell just parts if you want to do it your self...or have your local guy do it...
https://www.trutechtrans.com/Trutech...01-Basket.html
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 700r4 upgrade
Back in 2006-2008 when I was still messing with 700r4s I had 4 different ones built up completely with 5 pinon planets and all the latest stuff. Every last failure was a hard part!!! A 350 TBI with a Weiand 177 making no more than 400 hp and 450 ft\lbs of torque in a G20 van killed the longest lasting one in about 5K miles.
I drilled out the spit welds on the transmission crossmember mounts, moved it to the rear position, rewelded it into place and swapped a gazillion mile junkyard TH375/3L8E into it out of a 1987 G20 van and beat on it with the next 383 TPI making even more torque for over 2 years before pulling it off the road for the need of a complete front end and rear axle rebuild.
Re: 700r4 upgrade
Check out http://www.monstertransmission.com/
Re: 700r4 upgrade
http://cahallperformancetrans.com/#2787
Give him a call. He won't sell you bs. And I called him out of the blue looking for a trans guy. I was impressed he actually took almost an hour on the phone with me explaing what I need and what I dont. And alot of other info, free of charge with no offer on my end to buy. I liked him so much I drove 8hrs there and 8back from MA to pick up my trans so I could see his operation and meet him in person. If anyone has a passion for these trans its him. He won't sell you the latest greatest trick parts or sell you what you dont need. His customers give him plenty of feedback on what works and what doesnt. Alot of cars in the 9s with zero trick parts. When your putting a 4000+lb impala down a 1/4 in the 9s your are hitting the tires hard with alot of power.Not just one pass either. Any other builder out there can say this and that is what you need but zero to back it up. Drain your wallet and you dont know any better. I mean honestly how would anyone here know first hand what to buy and how it works and why in a 700r4 drag racing setup? You wont be dissapointed.
#42
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: 700r4 upgrade
jcllgo, Where are you located?
There are a only a handful of good 4L60/700R builders aross the country.
Maybe you're lucky and near one of them. ??
#43
